Trouble with cDAQ + NI-9263 + C# multiple channels
I am having trouble generating a waveform for AO0 (sine wave) and AO1 (cosine wave) respectively.
I can generate any waveform on a single channel, but generating waveforms to multiple channels eludes me.
Code:
I tried using AnalogMultiChannelWriter but I couldn't get the multidimensional double[,] set up correctly..
Anyone have advice for how to proceed? Is there an NI example? I couldn't find one in my local ...\National Instruments\NI-DAQ\Examples folder.
Thanks in advance,
Jon
(3,992 Views)
You need to put both channels in the same task and use the N-Channel writer instead of a single channel.
Santhosh
Soliton Technologies
(3,981 Views)
I'm not finding the "N-Channel writer"...
I tried using "NationalIstruments.DAQmx.AnalogMultiChannelWriter" but this proved not to be so intuitive.
Which class are you referring to?
(3,972 Views)
Yeah, that one, NationalInstruments.DAQmx.AnalogMultiChannelWriter
I am not so familiar with C# but know from LabVIEW APIs for DAQmx.
Santhosh
(3,939 Views)
Does anyone have an example of how to set up the multidimensional waveform for the 'AnalogMultiChannelWriter' class method 'WriteMultiSample'?
(3,907 Views)
Accepted by topic author EnJoneer
I figured it out. My multidimensional array was being populated in the wrong order.
This works:
(3,875 Views)
Can cRIO 9039 + 9263 work with measurement studio? It seems like my computer cannnot connect the cRIO successfully?    When I am running the examples, it always got stuck?   Could someone help me?
(3,558 Views)
