USB-4065 doesn't recognize by c# application
I'am new user. I'm devoloping an application with  two instruments: usb-6509 and usb-4065.
1) I have no problem with usb-6509. Perfect.
2) I have problems with usb-4065. Installation, driver and dll are ok. I work fine by Measurement & Automation Explorer. My application doesn't recognize the AI channel because when I debug this line of my code:
 string[] channels = DaqSystem.Local.GetPhysicalChannels(PhysicalChannelTypes.AI, PhysicalChannelAccess.External);
returns array[0], and so when I debug:
 myAIChannel = analogInTask.AIChannels.CreateVoltageChannel("Dev2/ai0","",AITerminalConfiguration.Differential,
                                                             0,10,AIVoltageUnits.Volts);
I have an exception.
I don't understand. Can you help me?
Thanks in advance
Message 1 of 9
(5,782 Views)
The USB-4065 uses the NI-DMM API, not the NI-DAQmx API.
NI-DMM 16.0
NI-DMM .NET Class Library 15.2
Tobias
Principal Software Engineer
Driver Software
Message 2 of 9
(5,777 Views)
Thank you Tobias for prompt reply.
Now, I'm downloading the packets.
What must I do after this step?? I explain you. I referenced on my application two .dll files to work with usb-6509:
NationalInstruments.Common.dll and NationalInstruments.DAQmx.dll .
Will I have to reference other .dll? Have you got a simple example to work with usb-4065?
Thanks in advance
Message 3 of 9
(5,754 Views)
Yes, you will need to reference the DMM assembly.
The NI-DMM .NET installer will install multiple examples which you can reference. They will be installed to (assuming Windows 7+)
C:\Users\Public\Documents\National Instruments\NI-DMM\examples\DotNET 4.0\
Tobias
Driver Software
Message 4 of 9
(5,736 Views)
Thank you Tobias for reply.
I'm working with .NET 3.5 Framework.
I see 3.5 Framework DMM examples in following directory: C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET3.5\Analog In\Measure Voltage and I debug my same errors.
Is  the .NET 4.0 Framework the solution?
Thanks in advance.
Message 5 of 9
(5,722 Views)
What exception are you seeing? Without that information this will be very difficult to debug.
What DMM examples are in the directory you linked? I would not expect to see any DMM examples in the NI-DAQ folder since they are unrelated products.
The NI-DMM examples do require .NET 4.0.
Tobias
Driver Software
Message 6 of 9
(5,703 Views)
Hi Tobias,
I'm using wrapper niDMM.cs to resolve all my problems.
I developed a simpe that read voltage. Now I have another problem.
If I attach current too, my application doesn't read correctly.
Can you help me???
Message 7 of 9
(5,699 Views)
however, I have my same errors with examples in folder:
The application doesn't recognize the channel Dev1/ai0 (same problem with Dev1/ai1), instead it's all ok by NI MAX application.
Now, I read fine the voltage (I pass to init function Dev1) by wrapper niDMM.cs.
I have problems (see previous post) if I read voltage and concurrently.
I hope that all is clear.
Thanks.
Message 8 of 9
(5,695 Views)
Accepted by topic author SimoneMarchettiEDA
Could you please post a snippet of your code?
NI-DMM devices are not accessed like NI-DAQmx devices are, so I'd like to see that you're using the DMM functions instead. That error looks to be coming from NI-DAQmx calls, which won't work for any DMMs. I assume that "Dev1" is your USB-4065?
Additionally, DMMs cannot read both Voltage and Current simultaneously. They can only read one or the other at a time, and to switch between them requires additional calls to change between state.
This link may help with some basics, although it contains a lot of information: http://www.ni.com/tutorial/3297/en/#toc1
Tobias
Driver Software
Message 9 of 9
(5,692 Views)
