USB6501 switching a resistor (using a digital output) with visual studio (vb.net or C#)
I am an absolute beginner and trying to work with USB 6501 and vb.net
I want to use a digital output to switch a resistor to an existing one in parallel. Please see the attachment.
MyVB code:
   Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim OUT() As Boolean = {True}
        myUSB6501Task = New Task
        'Create a virtual channel
        myUSB6501Task.DOChannels.CreateChannel("Dev3/port0/line0", "", ChannelLineGrouping.OneChannelForAllLines)
        myUSB6501Task.Control(TaskAction.Verify)
        Dim SYS1OUT As New DigitalSingleChannelWriter(myUSB6501Task.Stream)
        SYS1OUT.WriteSingleSampleMultiLine(True, OUT)
   END Sub
It does not work and I do not know why.
I am grateful for every hint.
Lois
Message 1 of 10
(3,005 Views)
I would suggest looking at the example:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.0\Digital\Generate Values\WriteDigPort\VB
Message 2 of 10
(2,932 Views)
thanks for the example, I did it like this. I see no difference.
Regarding hardware, could anybody have a look at my attached pic?
How to wire this? Does the USB6501 work like a switch (without voltage) or is a voltage output directly?
Message 3 of 10
(2,884 Views)
Did you read the manual for the USB6501?
It is a DIO device .
Message 4 of 10
(2,878 Views)
yes, sure. I just wanna use it as apure DO.
Message 5 of 10
(2,830 Views)
As I wrote in the earlier post, you should look at the example program NI installs.
Message 6 of 10
(2,823 Views)
i don't think that it is a software problem than more a hardware issue. What do you say to my pic posted earlier? Is this ok? I am not a hardware guy 😉
Message 7 of 10
(2,820 Views)
when I measure resistance between P0.0 and GND, do I measure "endless Ohm" in case of not swithcing and "zero Ohm" in case of switching the output of NI device?
Message 8 of 10
(2,818 Views)
or does a voltage come out (e.g. 5V when switched and 0V when not switched)?
Message 9 of 10
(2,817 Views)
Can't help you any further.
Find someone at your employer to help.
Message 10 of 10
(2,815 Views)
