Unable to add class, Form, User Control, Component or Module to DAQ project
Running MS 8.0.1 on VS2005, latest XP. Have a DAQ project. When try to add a class using Project|Add Class I get the Add New Item Wizard and the only choices are DAQ, VISA, Instrument Driver or Search Online Templates. Same thing happens with Project|Add Windows Form, Add User Control, Add Component, Add Module.
Same behavior with add from Solution Explorer and right clicking.
Sounds like a bug. What is the workaround?
(3,786 Views)
Hi Steve,
I've noticed that when I go to Project >> Add Class, there is a tree of different "Categories" which starts with "Visual Basic (or C#) Items", then under that there is a "Measurement Studio" category. By default (in a NI DAQ Project) the Measurement Studio category is selected, and my options are fairly limited, much like you described.
If I select the top most node (Visual Basic C# Items), all the options you're normally familiar with are available.
Is this the case on your machine as well? Let us know Steve, Thanks.
Dan Weiland
(3,759 Views)
Dan,
You are right. Didn't notice that Measurement Studio was autoselected. When I select the next level up ('Visual Basic Items') I see all the usual stuff.
Problem solved.
Steve
(3,756 Views)
