Undo zoom in ContinuousChart
Hey,
I use a graph whose x-axis runs all the time and the adjuster is ContinuousChart. When I zoom it works fine, and continues to run the x-axis relativistically. But when I try to undo the zoom it does not work. [You can easily see this in your examples - in the example of Charting].
Is there a way to zoom out/undo zoom in ContinuousChart?
(2,628 Views)
Accepted by topic author hodaya273
When there is a conflict between a user interaction and a data update, the graph will favor the data change and clear the interaction history. (I agree that the particular case of a chart adjuster would allow re-interpreting a zoom interaction as a more general "window" change that still made since to undo, but the graph does not go to that level of detail.)
There is no configuration option to allow undoing a zoom after a range adjustment. To achieve that effect, you would need to track the zoom level separately, and perform "undo" changes in your own event handler. For example, if you always want to zoom in on the latest data, you could use a slider to control the zoom level, and update the axis range from the slider's value changed event.
~ Paul H
(2,613 Views)
