Unhandled Exception thrown occurred in NationalInstruments.Vision.Common.dll
Hi there,
I am trying to run the C#.net example pattern matching code (running Visual Studio 2008 .NET framework 3.5).  When Algorithms.Extract is called, I got an exception:
An unhandled exception of type 'NationalInstruments.Vision.VisionException' occurred in NationalInstruments.Vision.Common.dll
This happen after I load an image in and draw a rectangle around the pattern I want to match.  Then click on the LEARN button.
Any help would be much appreciated.
Jim
Here is the code:
 private void learnPatternButton_Click(object sender, EventArgs e)
            learnPatternButton.Text = "Learning...";
            // Extract region corresponding to the region of interest in the image window
           Algorithms.Extract(imageViewerMain.Image, imageViewerPattern.Image, (RectangleContour)imageViewerMain.Roi[0].Shape);
            imageViewerMain.Roi.Clear();
            // Learn template
            Algorithms.LearnPattern(imageViewerPattern.Image);
            learnPatternButton.Text = "Learn Pattern";
            // Enable the Match button and disable the Learn button
            learnPatternButton.Enabled = false;
            matchPatternButton.Enabled = true;
(4,033 Views)
Hello Jim
Thank you very much for bringing this to our attention.  Can you please site the location of this example?  As well, would you mind posting a screenshot of the error you are receiving?  Thank you very much!
Sincerely,
Greg S.
(4,020 Views)
Hi Greg,
Thanks for the reply.  I've solved the problem.  It was just licensing issue.
Jim
(4,007 Views)
