Upgrading to VB.NET from VB6
I made a simple dummy program in VB6 that uses a CWDSP control and a CWGraph control.  I then opened the project in VB2008 and allowed the  Upgrade Wizzard to convert my project, which it did - but with warning messages about late binding.
This codes runs ok.
Private Sub Command1_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles Command1.Click
Dim z As Object
'UPGRADE_WARNING: Couldn't resolve default property of object CWDSP1.GaussNoise(). Click for more: 'ms-help://MS.VSCC.v90/dv_commoner/local/redirect.htm?keyword="6A50421D-15FE-4896-8A1B-2EC21E9037B2"'
'UPGRADE_WARNING: Couldn't resolve default property of object z. Click for more: 'ms-help://MS.VSCC.v90/dv_commoner/local/redirect.htm?keyword="6A50421D-15FE-4896-8A1B-2EC21E9037B2"'
z = (CWDSP1.GaussNoise(500, 1, 17))
CWGraph1.PlotY(z)
End Sub
Howver, if I change the code  to implement early binding - I get an exception error on the call to generate the noise waveform.
Dim z As Object
 Dim DSP As CWAnalysisControlsLib.CWDSP DSP = New CWAnalysisControlsLib.CWDSP
'z = (CWDSP1.GaussNoise(500, 1, 17))
z = (DSP.GaussNoise(500, 1, 17))
CWGraph1.PlotY(z)
End Sub
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
What is needed to make the early binding work ?
(10,280 Views)
Hello Jason,
Is this happening on all ActiveX controls or only National Instruments controls?
Does the "Click for more" give you any useful information?
I looked around and found quite a few people on forums across the web with a similar problem using COM components in .NET, some of these suggested that using a non-visible control was the issue. Did you actually place the Graph on a form in the VB6 project or are you simply declaring it in the code?
It's strange that the upgrade wizrd wouldn't add a wrapper like .NET normally does with COM components, this could be an issue with the upgrade wizard.
With warm regards,
David D.
(10,256 Views)
Hi Jason,
Try this
 Dim DSP As AxCWAnalysisControlsLib.AxCWDSP = New AxCWAnalysisControlsLib.AxCWDSP() Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Controls.Add(DSP)  'you still have to add the control
End Sub
Dim z As Object
Try
z = DSP.GaussNoise(500, 1, 17)
Me.CWGraph1.PlotY(z)
Exit Sub
 Catch Exc As Exception
MessageBox.Show(Exc.Message)
End Try
End Sub
Curt
(10,243 Views)
