08-25-2011 02:59 PM
When using IMAQdx in Visual Studio 2010 (C#), I received an error message which requires me to refer to an older verison of NI Common (8.7.35.131), which I don't have (I have 9.1.40.159). Is there anyway to walkaround, or where can I find the older version?
My sole purpose is to operate cameras via GiGE vision.
Thanks!
Best,
Yi
08-29-2011 06:44 PM - edited 08-29-2011 06:45 PM
Hi Yi,
I was able to find someone with a similar problem in this forum post. Let me know if this looks like a similar error to yours, and if any of the steps listed help at all. Additionally, I've seen similar issues in the past solved by updating to a more recent version of the drivers. Let me know if this helps, or if you have any updates on the issue.
08-31-2011 01:52 PM
Hi Kyle,
Thanks for your reply! My problem is a little different... I actually have problem compiling my code:
Error 1 The type 'NationalInstruments.ISupportSynchronizationContext' is defined in an assembly that is not referenced. You must add a reference to assembly
'NationalInstruments.Common, Version=8.7.35.131, Culture=neutral, PublicKeyToken=18cbae0f9955702a'.
I checked GAC, the config file (NationalInstruments.Common.config) looks like this:
<configuration>
<runtime>
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
<assemblyIdentity name="NationalInstruments.Common" publicKeyToken="dc6ad606294fc298"
culture="neutral" />
<bindingRedirect oldVersion="7.0.0.275-7.1.40.999"
newVersion="9.1.40.159" />
<bindingRedirect oldVersion="8.0.40.100-8.0.40.999"
<bindingRedirect oldVersion="8.1.40.100-8.1.40.999"
<bindingRedirect oldVersion="8.5.40.100-8.5.40.999"
<bindingRedirect oldVersion="8.6.40.100-8.6.40.999"
<bindingRedirect oldVersion="8.7.40.100-8.7.40.999"
<bindingRedirect oldVersion="8.9.40.100-8.9.40.999"
<bindingRedirect oldVersion="9.0.40.100-9.0.40.999"
<bindingRedirect oldVersion="9.1.40.100-9.1.40.158"
</dependentAssembly>
</assemblyBinding>
</runtime>
</configuration>
It didn't try to redirect 8.7.35.131. But even if I manually edit the file to do it, compiler still reports error... (I'm using MS VS .Net 2010)
I already installed the newest driver (August, 2011). I read from the release note that its development enviroment includes VS .Net 2005/2008, but doesn't mention VS2010...
P.S. In my code, if I reference NI Common 9.0.40.610 (for vs 2008), it compiles without a problem...haven't had a chance to test the code with camera yet. Will update later.
Best,
Yi
08-31-2011 02:27 PM
Sorry about a typo in my previous post. NI Common for 2008 should be 9.1.35.139
09-01-2011 10:36 AM
Another possibility here is that it could be a .NET version issue. Can you try changing your project settings to target .NET 3.5 and see if that makes any difference?
09-22-2011 03:29 PM
Update:
NI Common 9.0.40.610 (for vs 2008) works just fine with VS2010 and .net 4... Good enough for me.
