Using C# and VISA to open a Serial Resource
This is my source code:
           But when these code running, I found wasting long time for open a serial resource,wha's problems?
            SerialSession serialResource = null;
            try
                serialResource = (SerialSession)ResourceManager.GetLocalManager().Open(devResource);
            catch(Exception ex)
                throw new Exception(ex.Message);
            serialResource.BaudRate = 38400;
            serialResource.DataBits = 8;
            serialResource.StopBits = StopBitType.One;
            serialResource.Parity = Parity.None;
            serialResource.FlowControl = FlowControlTypes.None;
            return serialResource;
(5,129 Views)
How long will you wait? And after this period, is all following OK?
NI Application Engineer
(5,106 Views)
I will wait for about one minute, and following operation to the serialPort is OK, such as Read/Write!
The VISA version that i installed  is 3.5, the setup file is visa350full.exe.
Thanks you!
(5,078 Views)
I'm not familiar with VISA programming in C#. But maybe you can refer to this example and see if you still have the problem when using this example code.
Thanks.
http://zone.ni.com/devzone/cda/epd/p/id/4859
(5,058 Views)
