Using imgDisposeBuffer with C++ CLR
I'm using IMAQ in VisualStudio 2005, writing C++ (using MS' CLR). Things work fine until I attempt release an IMAQ buffer using the imgDisposeBuffer function. When I do that, it returns status xbff600a0 which I believe means "The given buffer wan't created by the NI-IMAQ driver."
What are the possible causes for imgDisposeBuffer to return that status?
TIA -
James Crain
Code follows ----------------------
I allocate 6 or 7 buffers using imgCreateBuffer, fill them with calls to imgSnap, and then call imgDisposeBuffer. There are no buffer lists, rings or other advanced features being used. It's a very plain vanilla use of IMAQ.
Buffer allocation:
typedef uInt16*                PWORD;
mpBuffers = new PWORD[mBandCount];
for (i = 0; i < mBandCount && imgStatus == IMG_ERR_GOOD; i++)    {
    imgStatus = imgCreateBuffer (mSID, IMG_HOST_FRAME,
                                         lSize, (void **) &mpBuffers[i]);
Buffer use:
IMAQ_STATUS snapFrame (int Band)        {
    System::Int32    imgStatus = IMG_ERR_GOOD;
    imgStatus = imgSnap (mSID, (void **) &mpBuffers[Band]);
    return imgStatus;
Buffer disposal:
for (i = 0; i < mBandCount; i++)    {
    imgStatus = imgDisposeBuffer (mpBuffers[i]);
delete [] pBuffers;
(4,047 Views)
Hello James,
It looks like you might be passing the pointer to the array of buffers instead of the actual buffers that you created.
Take a look at the LL Ring example:
C:\Program Files\National Instruments\NI-IMAQ\Sample\MSVC\Ring\LL Ring
This example is essentially a “bare bones” Ring that uses imgDisposeBuffer to dispose of an array of buffers after the image acquisition is complete.
Luke H
(4,025 Views)
Luke
Thanks for the reply. What it turned out to be was a type difference between the way I had declared the function in my header file and the way I was calling it at runtime.
In case anyone else is interested, here are the details:
1. Function declaration:
typedef long  IMAQ_STATUS;
#define IMAQ_PREFIX [DllImport("Imaq.dll")]
IMAQ_PREFIX IMAQ_STATUS imgDisposeBuffer(void* bufferPtr);
2. Invocation that returns error (and does not release memory):
 imgStatus = imgDisposeBuffer (pBuffers[i]);
3. CAST, then invocation doesn't return error (and does release memory):
imgStatus = imgDisposeBuffer ((void *) pBuffers[i]);
(3,979 Views)
