11-17-2015 03:36 AM
I am reading in a generated sine wave and it seems to be working correctly, but I need to be able to find the peak as I am going to be comparing the voltage and current of an AC circuit when I get the basics working. The problem I'm having is that the peak detect wont work on the graph as I believe it does not just contain exclusively integer values, is there a way of just taking integer values from the graph and using the peak detect function.
The following is the code I have so far, the daq task was all completed using the wizard so it is just standard.
Public Class Form1
Dim amplitudePeak() As Double
Dim waveform() As Double
Dim locationPeak() As Double
Dim secondDerivativePeak As Double
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Try
Dim acquiredData() As NationalInstruments.AnalogWaveform(Of Double) = DaqTaskComponent1.Read
ACsignal.PlotWaveforms(acquiredData)
Catch ex As NationalInstruments.DAQmx.DaqException
MessageBox.Show(ex.Message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
End Try
End Sub
Private Sub DaqTaskComponent1_Error(sender As Object, e As DAQmx.ComponentModel.ErrorEventArgs) Handles DaqTaskComponent1.Error
'TODO: Handle DAQ errors.
Dim message As String = e.Exception.Message
MessageBox.Show(message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
DaqTaskComponent1.StopTask()
End Sub
Private Sub DetectionOfPeaks()
Dim peakPolarity As NationalInstruments.Analysis.Monitoring.PeakPolarity = Analysis.Monitoring.PeakPolarity.Peaks
Dim peakDetect As NationalInstruments.Analysis.Monitoring.PeakDetector = New NationalInstruments.Analysis.Monitoring.PeakDetector
ACsignal = waveform
'Detection of Peaks
peakDetect.Detect(waveform, True, amplitudePeak, locationPeak, secondDerivativePeak)
This is the main error I am experiencing
Error 3 Value of type '1-dimensional array of Double' cannot be converted to 'NationalInstruments.UI.WindowsForms.WaveformGraph'.
Any help is greatly appreciated!
11-19-2015 10:05 AM
Hello gary,
Is it possible to send me the command that you are using when you are calling DetectionOfPeaks?
Is it also possible to send a screenshot of the error message?
Jonas
Applications Engineer UK&IRE
11-19-2015 10:27 AM
Hi Jonas,
I managed to solve the problem I was having with the peak detect I used the following code to get the peak and number of peaks
Dim a() As Double
a = acquiredData(0).GetScaledData
initialthreshold = -2.4 'Setting the initial threshold'
initialwidth = 10 'Setting the initial width'
'To detect the associated peaks withing the wave'
peakdetect.Reset(initialthreshold, initialwidth, 0)
peakdetect.Detect(a, True, amplitudePeak, locationPeak, secondDerivativePeak)
Now the graph is plotting fine, there is one more problem I am having, is there anyway that with the given "a" max amplitude along the Y axis, I am able to get a value for the corresponding X axis value which in this case would be a time value. As I am inputting 2 sine waves and I need to find the difference on the X axis between the 2 peaks. This is what I have so far,
Dim a() As Double
Dim b() As Double
b = acquiredData(1).GetScaledData
peakdetect.Detect(b, True, amplitudePeak, locationPeak, secondDerivativePeak)
'To display the number of peaks found in signal
numOfPeaksFound = amplitudePeak.Length
peaksFoundNumericEdit.Text = numOfPeaksFound
peakAmplitudeNumericEdita.Value = a.Max
peakAmplitudeNumericEditb.Value = b.Max
Thank you for the help it is greatly appreciated!
Gary
