Using shortkeys with switch form controls
Hi, i'm using VB.Net 2005.  I have an application that controls several valves so I'm using digital output to turn them on and off.  Right now I have an On/Off button and an led to indicate whether the output is high or low.  With the button i can use a shortkey and it works.  But i would like to change from a button to a switch and still use the shortkey.  However it gives me a build error when i tried.  Here is how i'm handling the keydown event:
Private
Sub Form1_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles Me.KeyDown
If e.KeyCode = Keys.F1 Then
Valve1_Switch_StateChanged(sender, e)
End If
When i did this with the button_click event it worked but when i do this with the switch i get this error when trying to build:
 Value of type 'System.Windows.Forms.KeyEventArgs' cannot be converted to 'NationalInstruments.UI.ActionEventArgs'.
Is there any way around this?
BienoJ
Message Edited by BienoJ on 04-17-2008 11:21 AM
(4,123 Views)
Hi BienoJ,
You need to create a new instance of the ActionEventArgs type and use that to send into your switch changed event handler. So you should say something like:
   D
im myArgs As ActionEventArgs = New ActionEventArgs(UI.Action.ByKeyboard)
Switch1_StateChanged(sender, myArgs)
End If
Best Regards,
Message Edited by Jonathan N on 04-17-2008 11:59 AM
Jonathan N.
(4,118 Views)
I actually figured out another way to do it but thank you for the quick response.
BienoJ
(4,111 Views)
