VC# and DAQmx to send output on PFI7 of a 6035E to trigger SC-2040 track/hold circuit
I'm probably just a bit dense, but I can't figure out how to arrange a signal output to appear on PFI7 of my 6035E to fire the track/hold circuit on my SC-2040 sample & hold. The DAQ is directly connected to the S/H with a 68-pin cable, so the trigger input on the S/H is directly routed to PFI2 on the DAQ. I'm using C# and Measurement Studio 7.0. Here are my design goals:
1. rising edge trigger appears on PFI2 and kicks off a countdown (fine, got this worked out)
2. once the countdown is complete, send digital high to PFI7 and switch the SC-2040 into hold mode (?)
3. countdown a bit more to allow the SC-2040 outputs to settle, then read samples from various analog channels (no problems here)
4. send digital low to PFI7 and switch the SC-2040 back into track mode. (?)
5. rinse, repeat.
Advice much appreciated.
Cheers,
E Power
(2,909 Views)
Thank you for contacting National Instruments.
There is no way to internally route a Digital Output (DO) to a PFI Line. What you should do is externally wire a DO Line to the PFI7 line. For example, wiring pin 52 to pin 38 would connect the digital line "P0.0" to PFI7. Then it is simply a matter of writing a digital value to "P0.0".
I hope this helps. Let me know if you have any further questions.
Sean C.
(2,894 Views)
