05-19-2008 08:56 AM
05-19-2008 09:40 AM
05-19-2008 09:43 AM
05-20-2008 08:32 AM
05-20-2008 08:37 AM
05-22-2008 08:55 AM
05-22-2008 09:07 AM
05-23-2008 09:39 AM
Hi Paul,
I have attached a different version of nianlys.dll that I would like you to put in your C:\Program Files\National Instruments\Shared\Analysis\ directory. Take the one that is already there and move it to some location. Then copy the attached file to that Shared\Analysis\ directory. After that, run your test application and see if you get that memory error.
Best Regards,
05-23-2008 09:49 AM
I still get the following:
System.AccessViolationException was unhandled
Message="Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
Source="NationalInstruments.Analysis.Enterprise"
StackTrace:
at NationalInstruments.Analysis.Internal.k.a(Double[] A_0, Double[] A_1, Int32 A_2, Int32 A_3, Int32[] A_4, Double[] A_5, Int32 A_6, PolynomialFitAlgorithm A_7, Double[] A_8, Double[] A_9, Double& A_10)
at NationalInstruments.Analysis.Math.CurveFit.PolynomialFit(Double[] inputXData, Double[] inputYData, Int32 order, PolynomialFitAlgorithm fitAlgorithm, Double[]& coefficients, Double& mse)
at WindowsFormsApplication1.Form1.button2_Click(Object sender, EventArgs e) in C:\Temp\Example\WindowsFormsApplication1\WindowsFormsApplication1\WindowsFormsApplication1\Form1.cs:line 39
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at WindowsFormsApplication1.Program.Main() in C:\Temp\Example\WindowsFormsApplication1\WindowsFormsApplication1\WindowsFormsApplication1\Program.cs:line 18
at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
InnerException:
Paul
05-23-2008 09:57 AM
