Verify versus start
Hello-
 When I have a PCI-6111 setup for aquisition faster that 1mhz, I get an error very shortly after the task I get the following message:
Measurements: Data transfer has been stopped to prevent the computer from becoming completely unresponsive. Could not transfer enough data to satisfy the data transfer requirements with Interrupts as the Data Transfer Mechanism.
Reduce your Sample Clock Rate, use DMA as your Data Transfer Mechanism, or use a different Data Transfer Request Condition.
Task Name: _unnamedTask<5A>
Status Code: -200322
I am assuming that this message is correct because I have set the transfer mechanism to Interrupts. What I want to know is; why did the task verify if it was going to end up throwing up this message?
-Bill
(3,650 Views)
Hi Bill,
I’m not sure I understand your question. I believe the program is giving you this warning message so the computer doesn’t hang trying to perform the task, so the task verify this to prevent the system from locking up because of limited resources. Please, let me know if I misunderstood your question.
Ana P
(3,616 Views)
I do not get the error when I verify the task, I get the error almost immediately after I start to run the task.
This surprised me because I would have thought that an error like that would have been caught verify.
(3,614 Views)
