VisaNS MessageBasedSession BeginWrite is not calling callback async method
Hello team,
I was trying the below code in  a C# Winform application , in the writeSession() method once the BeginWrite is done, it needs to call the AsyncCallBack method OnWriteComplete(), which is not happening, I do not see any exception or error. Could you please check if I am doing anything wrong?
private MessageBasedSession mbSession;
private IAsyncResult asyncHandle = null;
private void writeSession(string command)
try
SetupWaitingControlState(true);
string textToWrite = ReplaceCommonEscapeSequences("?C");
asyncHandle = mbSession.BeginWrite(
textToWrite,
new AsyncCallback(OnWriteComplete),
(object)textToWrite.Length);
OnWriteComplete(asyncHandle);
catch (Exception exp)
MessageBox.Show(exp.Message);
private string ReplaceCommonEscapeSequences(string s)
try
return (s != null) ? s.Replace("\\n", "\n").Replace("\\r", "\r") : s;
catch (Exception ex)
log.Error("Exception in" + MethodBase.GetCurrentMethod(), ex);
return null;
private void OnWriteComplete(IAsyncResult result)
try
SetupWaitingControlState(false);
mbSession.EndWrite(result);
ioStatusLabel.Text = "I/O Status:" + mbSession.LastStatus.ToString();
writeLabel.Text = "Write: " + ((int)result.AsyncState).ToString();
// Always perform a read after a Write
readSessionsButton_Click(null, null);
(3,083 Views)
Please ensure you are creating the new AsyncCallback as defined in the documentation for the BeginRead Method
Applications Engineering
(3,065 Views)
Thank you for the reply. If you see my code above, I am using new AsyncCallback as the parameter to BeginWrite().
Moreover I have another problem where the below overloaded version of BeginWrite() always returns the AsyncState as null. Below is the code please let me know if anything is wrong. I have the session created as well.
byte[] bytes = Encoding.ASCII.GetBytes(textToWrite);
IAsyncResult asyncHandle = mbSession.BeginWrite(bytes,0,bytes.Length);
But the below overloaded version of BeginWrite with AsyncCallback code returns a value for AsyncState.
asyncHandle = mbSession.BeginWrite(textToWrite, new AsyncCallback(OnWriteComplete),(object)textToWrite.Length);
(3,004 Views)
