Visual Studio 2019 freezing after opening .sln file with 2019 Measurement Studio libraries
Using;
Visual Studio Professional 2019
Measurement Studio 2019
Windows Forms
.NET Core 3.1
Somewhat of a strange interaction, every time I add a MS library to my project (Professional Analysis Library & Windows Forms User Interface Control Library) it works OK, so long as I keep the project open. As soon as I close the project and try and re-open it Visual Studio just freezes and goes into "not-responding".
I work in a fairly restrictive network environment, so I'm not sure if MS is trying to do some sort of licensing checks over the net which are getting blocked by a firewall or what else might be causing this behavior.
Has anyone else experienced this issue/found a suitable workaround?
Cheers,
Michael
(2,362 Views)
My setup uses a network license server, and I have found MS hits the license server regularly. If I disconnect from the network, I seem to lose local rights to MS after a period of time.
This doesn't seem to be a problem with local licenses.
(1,918 Views)
Does 2019 Measurement Studio have NI4882.dll?
Ed
(1,883 Views)
