WPF ActiveX CW 3D Graph implementation
Hello, i'd like to use ActiveX CW 3D Graph to display multiple curves and see some data in 3 dimension.
So, i already added it through winforms library and WindowsFormsHost to the test library and display single curve.
Could you please help me with following issue that need to be resolved for this component:
1. How to display different curves with different colors?
2. How select single data point and show tooltip with datapoint data in WPF inside 3D Plot?
3. How to select specific segment and highlight inner data points for the curve (curves) in 3D Plot?
4. How to set specific camera view (top-center, left-center, bottom-center)?
5. How to highlight with specific image start data point of curve in 3D Plot?
6. How to changes scale of each axis based on min/max value of axis outer source?
7. How to autofit to visible area data on the 3D Plot?
Thanks.
(1,495 Views)
Hello, i'm still waiting for respond.
I appreciate any help regarding usage of 3D graph in WPF
Thanks.
(1,421 Views)
