WPF Legend Binded to Graph.
I have a ni:Legend object binded to the Plots of my Graph object. Which Property of my Plot should I set from the C# code to see it displayed in the Legend window?
   <ni:Legend Name="MyLegend" ItemsSource="{Binding ElementName=MyGraph, Path=Plots}" />
        <ni:Graph Name="MyGraph" DataSource="{Binding UpdateSourceTrigger=PropertyChanged}">
            <ni:Graph.Plots>
                <ni:Plot/>
            </ni:Graph.Plots>
</ni:Graph>
MyGraph.Plots[0].??? = ???
(6,530 Views)
By default, the data template used for plots in the legend displays the Label property.
~ Paul H
(6,521 Views)
Thanks!
I am almost there now:
   var MyLabel1 = new Label();
            MyLabel1.Content = "Something";
            MyGraph.Plots[0].Label = MyLabel1;
But what I get in the Label window is. System.Window.Controls.Label: Something
How do I get rid of the unwanted information, and display only the Content of the Label?
(6,512 Views)
Accepted by topic author jtamaska
The legend uses a WPF ContentPresenter to display the plot Label property. In the case of UI elements, it appears that ContentPresenter defaults to using the ToString representation, instead of the element itself.
To display content like "Something", you will want to assign that content directly to the plot Label property:
    MyGraph.Plots[0].Label = "Something";
If you want to specifically show a WPF Label content control in the legend, you can use the LabelTemplate property:
    <ni:Graph.Plots>
        <ni:Plot>
            <ni:Plot.LabelTemplate>
                <DataTemplate>
                    <Label Content="{Binding}" />
                </DataTemplate>
            </ni:Plot.LabelTemplate>
        </ni:Plot>
    </ni:Graph.Plots>
~ Paul H
(6,505 Views)
That did the trick! Thank you!
(6,473 Views)
