09-18-2019 03:15 AM
I have VS 2017 WPF project and using measurment studio waveform graph . Graph plot area is black so when I select axis max or min value on graph to change range , its color turning black and i can't see. How can i change focused axis label backround color . I have attached screenshots.
Best Regards,
09-18-2019 10:48 AM
The range editor works by adding an unstyled TextBox to an adorner layer above the graph. Unfortunately, I have not been able to apply an implicit style to that editor (it always uses the system default TextBox style on my machine).
Based on your screenshots, though, it appears you have found a way to change it (at least as far as setting the background to match the foreground 🙂. You may want to experiment with any TextBox styles in your application. If you have a small example program you could share that reproduces the issue, I would be happy to dig into it further.
