WPF custom ValueFormatter fails in 2015
This code worked at MS 2013:
public class MyGeneralValueFormatter : GeneralValueFormatter
return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, _units);
protected override UIElement VisualizeCore<TData>(TData value, ValuePresenterArgs args, UIElement existingVisual)
UIElement element = base.VisualizeCore<TData>(value, args, existingVisual);
if (args.Context is Axis<TData>)
var axis = (Axis<TData>)args.Context;
if (axis.Orientation == System.Windows.Controls.Orientation.Horizontal)
if (_showOnlyMinMaxAtX)
Range<TData> range = axis.Range;
var comparer = range.Comparer;
RelativeAlignment alignment =
comparer.Compare(range.Minimum, value) == 0 ? RelativeAlignment.Near :
comparer.Compare(range.Maximum, value) == 0 ? RelativeAlignment.Far :
RelativeAlignment.Center;
//RegionPanel.SetRelativeHorizontalAlignment(element, alignment);
element.Opacity = comparer.Compare(range.Minimum, value) == 0 || comparer.Compare(range.Maximum, value) == 0 ? 1.0 : 0.0;
else
element = new Viewbox { MaxWidth = 60, Width = 60, Stretch = System.Windows.Media.Stretch.None, Child = element };
return element;
1. This doesn't even compile:
2. This crashes with error: Specified element is already the logical child of another element. Disconnect it first.
(5,200 Views)
Hi, eugenem
I can address one of your concerns immediately. In Measurement Studio 2015, RegionPanel was changed to RelativePanel, which is why that line no longer compiles.
To address your other concern, I will need more context for this code. Syntactically, I don't believe your code (as is) would have compiled in any version of Visual Studio. It is also unclear how the value formatter class relates to the VisualizeCore<TData> override method. Can you please provide a more complete snippet? Please see the following copy of the code you provided, where I have added comments with questions. I also highlighted the place I changed RegionPanel to RelativePanel.
// This is a class definition. Why is it returning a value?
// Where does this method belong? Currently it does not have a containing class.
                RelativePanel.SetRelativeHorizontalAlignment(element, alignment);
        else
    return element;
Daniel Dorroh
(5,194 Views)
sorry, I've deleted too much of the class. there is the full version:
  public class RCAGeneralValueFormatter : GeneralValueFormatter
    private string _units;
    private bool _showOnlyMinMaxAtX;
    public RCAGeneralValueFormatter(string format, string units, bool showOnlyMinMaxAtX)
      : base(format)
      _units = units;
      _showOnlyMinMaxAtX = showOnlyMinMaxAtX;
    protected override string FormatCore<TData>(TData value, ValuePresenterArgs args)
            if( comparer.Compare(range.Minimum, value) != 0 && comparer.Compare(range.Maximum, value) != 0)
              return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, "");
      if (false && args.Context is Axis<TData>)
        else
      return element;
(5,192 Views)
Accepted by topic author eugenem
Thank you for posting the rest of the code.
It looks like instead of using your override for VisualizeCore<TData>, you can make use of the new properties, RangeLabeledDivisions.MaximumLabelAlignment and RangeLabeledDivisions.MinimumLabelAlignment. For example:
<ni:Graph>
    <ni:Graph.Axes>
        <ni:AxisDouble Orientation="Horizontal">
            <ni:AxisDouble.MajorDivisions>
                <ni:RangeLabeledDivisions MaximumLabelAlignment="Far" MinimumLabelAlignment="Near" />
            </ni:AxisDouble.MajorDivisions>
        </ni:AxisDouble>
    </ni:Graph.Axes>
</ni:Graph>
As for creating a new ViewBox, is there a reason you don't just set the UIElement properties directly on element? It seems like setting the MaxWidth on element would have the same effect as what you are doing there.
Daniel Dorroh
(5,179 Views)
