Waveform Graph Grid Lines
I would like to add gridlines to my waveform graph. Not just ticks on the axis, but actual lines that go across the entire graph from both major and minor tick marks from each axis. Is this possible?
(8,348 Views)
Accepted by topic author VHalbur
Hi VHalbur,
To add grid line to your waveform graph you will need to change some of the default properties of the X and Y axis. If you go to the properties collection, under the section major and minor divisions you will find all of the grid properties. I hope that this helps.
Perry S.
(8,334 Views)
