Waveform Graph Panning Error
I have a simple test app built off the NI example.  I changed the X-axis to DateTime format.
Panning works as expected-- allowing free access to ranges not on the original plot.  However, when I add actual data to the plot,  it throws an app killing error when I try to pan below the X=0 point.
The error is coming out of the graph component, so I can't see a way to catch it.
Any ideas on how to prevent this -- or at least trap it?
Tom
(4,605 Views)
Hi Tom,
Could you post your program?
(4,583 Views)
Its all in this Main Form. (Is there a way to put attachments in this forum?  Otherwise, here's the text dump).
Run btnGetData for a few points. Stop it and try to pan X<0. Crashes on me everytime (Windows XP sp2. VS2003).
Tom
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
// Add reference to NationalInstruments.Analysis.Professional
using NationalInstruments.Analysis.SignalGeneration;
using NationalInstruments;
using NationalInstruments.UI;
using NationalInstruments.UI.WindowsForms;
namespace BurnIn_Plot
public class BurnIn_Plot_Form : System.Windows.Forms.Form
#region Windows Form Designer generated code
   [I removed this stuff to save space]
#region Member variables
private NationalInstruments.UI.WindowsForms.WaveformGraph waveformGraph1;
private NationalInstruments.UI.XAxis xAxisForm;
private NationalInstruments.UI.YAxis yAxisForm;
private System.Windows.Forms.Button btnGetData;
private System.Timers.Timer simulateTimer;
private System.Windows.Forms.Button btnStopData;
private NationalInstruments.UI.WaveformPlot SineWavePlot;
private NationalInstruments.UI.WaveformPlot ScrollingSineWavePlot;
private System.Windows.Forms.TextBox textBox1;
private const int NUM_PTS=50;
private double[] WaveData;
private static int count=0;
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.Container components = null;
#endregion
#region Constructor
public BurnIn_Plot_Form()
// Required for Windows Form Designer support
InitializeComponent();
// Set up waveform plots to hold the plotting data
SineWavePlot.LineColor = System.Drawing.Color.Black;
SineWavePlot.XAxis = this.xAxisForm;
SineWavePlot.YAxis = this.yAxisForm;
InitializePlot();
private void InitializePlot()
// Initialize XAxis of Plots -- both use the same one.
DateTime startTime= System.DateTime.Today; //DateTime.Now; // Hold for plotting data
xAxisForm.Mode=AxisMode.StripChart;
xAxisForm.MajorDivisions.LabelFormat= new NationalInstruments.UI.FormatString(
NationalInstruments.UI.FormatStringMode.DateTime,"HH:mm:ss");
xAxisForm.MajorDivisions.GridVisible=true; xAxisForm.MajorDivisions.GridColor= Color.Gray;
yAxisForm.MajorDivisions.GridVisible=true; yAxisForm.MajorDivisions.GridColor= Color.Gray;
xAxisForm.Range=new Range(startTime,TimeSpan.FromSeconds(300));
xAxisForm.MajorDivisions.Interval = 60;
yAxisForm.Range=new Range(-10,10);
yAxisForm.MajorDivisions.Interval = 2;
xAxisForm.AutoSpacing=false;
yAxisForm.AutoSpacing=false;
private void BurnIn_Plot_Form_Load(object sender, System.EventArgs e)
btnGetData.Enabled=true;
btnStopData.Enabled=false;
protected override void Dispose( bool disposing )
if( disposing )
if (components != null)
components.Dispose();
base.Dispose( disposing );
#endregion
#region PlotData Methods
private void btnGetData_Click(object sender, System.EventArgs e)
btnGetData.Enabled=false;
btnStopData.Enabled=true;
count=0;
WaveData = AcquireData(2, 6, 0, NUM_PTS, 0.25);
simulateTimer.Interval= 500;
simulateTimer.Enabled= true;
simulateTimer.Start();
private void simulateTimer_Elapsed(object sender, System.Timers.ElapsedEventArgs e)
if(count<NUM_PTS)
SineWavePlot.PlotYAppend(WaveData[count],5.0);
textBox1.Text =Convert.ToString( count++);
Application.DoEvents();
else
simulateTimer.Stop();
private double[] AcquireData(double frequency, double amplitude, double phase, double numberSamples, double noiseAmplitude)
SineSignal sineSignal = new SineSignal(frequency, amplitude, phase);
WhiteNoiseSignal noise = new WhiteNoiseSignal(noiseAmplitude);
SignalGenerator generator = new SignalGenerator(numberSamples, (long)numberSamples);
generator.Signals.Add(sineSignal);
generator.Signals.Add(noise);
return generator.Generate();
private void btnStopData_Click(object sender, System.EventArgs e)
#endregion
} // end class
} // end namespace
(4,582 Views)
Duh. That would be the "attachment box" down there.
Here's the project:
(4,570 Views)
Hi Tom,
Based on this discussion forum (Restrict Pan-Mode), I try adding the following lines to your program:
        waveformGraph1.XAxisRangeChanged += new XAxisEventHandler(waveformGraph1_XAxisRangeChanged);
        void waveformGraph1_XAxisRangeChanged(object sender, XAxisEventArgs e)
            if (e.XAxis.Range.Minimum < 0)
                xAxisForm.Range = new Range(startTime, TimeSpan.FromSeconds(300));
This will avoid the exception, and after speaking with R&D, this seems to be the best way available.
(4,557 Views)
