WaveformGraph to Image
I am interested in converting a WaveformGraph's System.Drawing.Graphics object used in the PrintPage handler to a System.Drawing.Image object. Here's what I'm trying to do:
Graphics g = e.Graphics;
Rectangle bounds = e.MarginBounds;
waveformGraph1.Draw( new ComponentDrawArgs( g, bounds ) ) ;
Image img = g.?? ;
Can this be done or is there a better method of doing this?
Thanks in advance!
Derek
Message 1 of 16
(6,837 Views)
Derek,
I am assuming e.Graphics is the Graphics object from the event arguments of the PrintPage handler.
I don't think there is a way to go from a Graphics object to an Image. You can create another Graphics object from an existing Image. For this example, assume that the Image that you are trying to create is a Bitmap. Then, your code would be modified to look something like this:
// This will draw the printed output to an image
// of type bitmap. You can substitute Bitmap
// to be any other Image derived type.
Bitmap img = new Bitmap(bounds);
Graphics imgGraphics = Graphics.FromImage(img);
ComponentDrawArgs( imgGraphics, bounds ) );
Hope this helps.
Abhishek Ghuwalewala
Measurement Studio
Abhishek Ghuwalewala | Measurement Studio | National Instruments
Message 2 of 16
(6,834 Views)
You don't convert a Graphics object to an image - the Graphics class provides the ability to draw to a device context where that context can be an image, the screen, a printer, etc. What you can do, though, is create an image, then get a Graphics object from the image, then drawing operations on that Graphics object will be directed to the image. So, for example, if you wanted to dynamically create an image and draw the WaveformGraph to it, you could do this:
using NationalInstruments.UI;
using System.Drawing.Imaging;
Size imageSize = new Size(300, 200);
using (Bitmap bitmap = new Bitmap(imageSize.Width, imageSize.Height, PixelFormat.Format32bppArgb))
using (Graphics g = Graphics.FromImage(bitmap))
waveformGraph1.Draw(new Compon
entDrawArgs(g, new Rectangle(new Point(0, 0), imageSize)));
- Elton
Message 3 of 16
(6,834 Views)
Hi Elton,
This is exactly what I want! I found a .NET Report Printing library that makes it very easy to print text, headers, footers, columns, tables, and images (via System.Image), but it does it separately from the PrintPage event handler. I couldn't figure out how to get the Image independently from this event.
Thanks again,
Derek
Message 4 of 16
(6,834 Views)
Hi Elton,
I finally had a chance to go back and work on this, but had a question. Your code does exactly what I need, but the image is not very good. I've attached an image of a portion of the app running and the print preview using your suggested method. It's very grainy. Any ideas on how to fix this?
Derek
Message 5 of 16
(6,835 Views)
Hi Elton,
I've attached a sample that demostrates this. The screenshots above don't really show the problem.
Derek
Message 6 of 16
(6,838 Views)
Has anyone found a better solution to this problem?
The print preview results are a little out-of-focus.
Philip Newman
General Dynamics
Electric Boat
Message 7 of 16
(6,568 Views)
Try making the size of the bitmap the same size as the graph control
private Image GetWaveformGraphImage()
            Size imageSize = waveformGraph1.Size ;
            Image bitmap = new Bitmap( imageSize.Width, imageSize.Height, PixelFormat.Format32bppArgb ) ;
            using ( Graphics g = Graphics.FromImage( bitmap ) )
                waveformGraph1.Draw( new ComponentDrawArgs( g, new Rectangle(new Point(0, 0), imageSize ) ) );
            return bitmap;
I think this should clear up the graph image.
Hope this helps.
Bilal Durrani
NI
Message 8 of 16
(6,560 Views)
great idea
thanks
Philip Newman
General Dynamics
Electric Boat
Message 9 of 16
(6,553 Views)
hi everybody
I have used waveformGraph in my code and I can show the data I give on the screen ok but does anyone know how I can get data that is shown on the screen anytime?
I mean is there any function I can use the get the data of the waveformGraph?
thank you
Message 10 of 16
(6,461 Views)
