Way to programmatically reset USB-6008 on memory overflow
I am using a USB-6008 with a VB.net Measurement Studio application and the Measurement and Automation Explorer for continuous samples at reading 8 samples at 256Hz.  When I am testing my configuration in MAX, after collecting less than one minute of data, without fail I get a Error -200361 Onboard Memory Overflow.  Once I get this error, I cannot collect a single data point without hitting the Error -200361.  Reseting the 6008 in MAX does not clear the error.  Currently, I have to physically unplug the USB-6008 before it can collect data again.
Is there a way to programmatically clear this error through Measurement Studio?  Is there a way to configure the USB 6008 so it could be used with long duration runs?
(4,380 Views)
One way to fix this is to:
  1. Unplug the USB-6008
  2. Clear All Device Associations from the NI Device Monitor
  3. Delete all Tasks and Virtual Channels from MAX
  4. Plug in the USB-6008 and reconfigure
Is there a way to programmatically Clear All Device Association and programmatically re-establish Tasks?  This would be useful for remote systems.
-Doug
(4,379 Views)
