What is Range IOpComparison argument for?
There are 2 overloads for Range but I can't find any examples on the 3rd argument - IOpComparison.
Could you please point me to some example or perhaps provide one... Curious what it does.
Thanks!
(3,583 Views)
Accepted by topic author kirko7
Hi kirko7,
The optional IOpComparison argument is for cases when you wish to specify a different or custom comparer for the TData values within that range. The documentation for this can be found in the Measurement Studio help within Visual Studio, including full documentation on the members of each class. I've linked the documentation for that specific Range constructor you are referencing, which describes IOpComparison as the instance of a comparer used to compare minimum and maximum. This would be useful in cases where the default comparison method would not suffice for your application when determining if something is within range or not.
Unfortunately I could not track down an example or a link to a help page, but you should be able to find the same documentation I looked at in the Measurement Studio Help from within Visual Studio. Just search for "Range(TData)" to find the Range Constructor page, and you should be able to navigate from there to the specific constructor and documentation on IOpComparison.
Charlie J.
(3,571 Views)
Thanks, I will take a look at some point... I was just curious as I notices the 3rd overload by accident (auto coplete option).
(3,568 Views)
