Hello everybody,
I am using analog output of USB-6002 for excitation of my circuit. Also, I use the analog inputs to read some test points.
The analog output is an arbitrary waveform which is limited to the finite samples and it is not going to re-written.
aoTask.Timing.ConfigureSampleClock("",
5000,
SampleClockActiveEdge.Rising,
SampleQuantityMode.FiniteSamples, finalWaveForm.Length);
aoWriter.BeginWriteMultiSample(false, finalWaveForm, analogOutputCallback, null);
The problem is that I can not determine when the analog output task is done and all the data is written in the physical AO pin in order to stop analog input task. The analog output callback function is called before the waveform is written in AO pin.
I appreciate it if somebody gives me an idea.
