Which Legend item is clicked?
If I put up a legend with my scatterplot and setup an OnClickLegend for the Click event in the legend, how do I know which Item it was that was clicked?
private void OnLegendClick(object sender, System.EventArgs e)
The System.EventArgs e is empty.
MS 7.1
VS 2003
C#
(3,459 Views)
You can do this by handling the Legend.MouseDown or Legend.MouseUp event and then using the Legend.GetItemAt method with the X/Y properties from the event arguments. If Legend.GetItemAt returns a non-null reference, that is the legend item that you clicked on. For example:
private void OnLegendMouseUp(object sender, MouseEventArgs e)
    LegendItem item = legend1.GetItemAt(e.X, e.Y);
    if (item != null)
        MessageBox.Show(item.Text);
- Elton
(3,444 Views)
That'll do it.  Thanks!
(3,441 Views)
