Hello
The license issue should not have anything to do with Whidbey and MStudio 7.0. Im curious though about how you got into this state.
Can you describe the order in which you installed and removed the different versions of MStudio?
Something to look into would be making sure the project license file ( license.licx) is referencing the correct versions of the UI assemblies. You can open up the licx file ( its a text file) and search and replace any invalid assembly version references. Below is an example of one of the strings in the license file.
NationalInstruments.UI.WindowsForms.ScatterGraph, NationalInstruments.UI.WindowsForms,
Version=7.0.0.341...
Try rebuilding the app once the license file has been updated.
Hope this h
elps
Bilal Durrani
NI
Bilal Durrani
NI
