This widget could not be displayed.
Why Does my Waveform Graph Turn to a Big Red X?
I am modifying my charts to increase flexibility and I'm having an issue that I've only seen once before and this issue was always on the first of several graphs to be written to and used to only happened on one system.  Now, on my development PC I am getting the same issue.  As soon as a write a value to the chart it turns to a big red X.  What is odd is that all other charts which are written to in the same loop operate just fine (charts 1-9).
Any ideas?
                                Dim ChartPrefix As String
                                Dim A As Int16
                                For cnt = 0 To 9
                                    ReDim ChartData(Charts(cnt).NumPlots, 0)
                                    For cnt2 = 0 To Charts(cnt).ChartChannels.Length - 1
                                        If Charts(cnt).ChartChannels(cnt2) <> "" Then
                                            ChartPrefix = Charts(cnt).ChartChannels(cnt2).Substring(0, 3)
                                            Select Case ChartPrefix
                                                Case "AI:"
                                                    For A = 0 To AIChannelCount - 1
                                                        'MsgBox(Charts(cnt).ChartChannels(cnt2).Remove(0, 3))
                                                        If AIChannels(A).Name = Charts(cnt).ChartChannels(cnt2).Remove(0, 3) Then
                                                            ChartData(cnt2, 0) = aiEngrUnits(A)
                                                            Exit For
                                                        End If
                                            End Select
                                        End If
                                    frmD.WaveformGraph(cnt).PlotYAppendMultiple(ChartData)
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 1 of 23
(6,960 Views)
Hello there,  This is definitly odd behavior,  I will be looking into the possible cause. If possible would you send me the files to save on time?
Message 2 of 23
(6,949 Views)
What files do you need?  The entire solution is faily large with many required input files.
Message 3 of 23
(6,947 Views)
Anything that would reproduce the current error with the large Red Box.
Message 4 of 23
(6,944 Views)
The times I have seen this in the past, it was related to an out of memory exception. What are the memory conditions like on your system?
Message 5 of 23
(6,941 Views)
Resources are fine.  Memory is around 50% max.  What makes it even more interesting is that it is selective.  It used to only happen on a laptop I have.  This was the first time I saw it on my development computer.  Now it has gone away again!  Going to be a difficult one.
Message 6 of 23
(6,938 Views)
Are you using any special values? Such as negative infinity, positive infinity or NaN? There are not any known issues with this currently, but they have been the source of similar bugs in the past.
Message 7 of 23
(6,935 Views)
No.  Outputing ~4000 and ~1000.
Message 8 of 23
(6,932 Views)
I got it to throw me an error on now a third computer.  Again it is the first chart that messes up.  All of the rest are OK.
Message 9 of 23
(6,922 Views)
I would still be interested in seeing the code that you are using which is creating this error.
Message 10 of 23
(6,917 Views)
