Why does visual studio 2003 show 9 boxes saying "unable to load parameter assistant provider" every time I start it?
I recently installed NIScope and the associated .NET APIs for my Visual Studio 2005 evironment and VS2005 it is working fine.  However, I am now having a problem with Visual Studio 2003 and measurement studio.  Every time I launch the application I get a flood of NI dialogs complaining that NI was "unable to load parameter assistant provider".   I've tried reinstalling measurement studio as this old thread suggests (http://forums.ni.com/ni/board/message?board.id=232&message.id=701#M701), but this didn't fix the problem.  I should say that this doesn't appear to cause any problems other than the annoying dialogs.  Someone in the same thread previous mentioned asked for some information " Could you please post your registry information located at: [HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders] I would also like to know the contents of the Common directory where MeasurementStudio is installed."
Here is the information requested in case it helps:
07/23/2003  02:06 AM           311,296 analysis.dll
07/23/2003  05:39 AM           172,032 AssistantEditorPkg.dll
07/23/2003  05:14 AM            20,480 MaxDyn.dll
07/23/2003  06:41 AM            40,960 MeasurementStudioPkg.dll
07/23/2003  05:21 AM           110,592 NationalInstruments.Cpp.Common.dll
07/23/2003  05:40 AM            32,768 NationalInstruments.Cpp.ComponentWizard.dll
07/23/2003  05:29 AM            28,672 NationalInstruments.Cpp.DAQmxAssistantWizards.dll
07/23/2003  05:28 AM            20,480 NationalInstruments.Cpp.IIOAssistantWizards.dll
07/23/2003  05:32 AM           114,688 NationalInstruments.Cpp.ProjectWizards.dll
07/23/2003  05:33 AM            53,248 NationalInstruments.Cpp.UpgradeWizard.dll
02/23/2007  08:19 PM            57,344 NationalInstruments.DAQmx.Common.dll
02/23/2007  08:19 PM            66,048 NationalInstruments.DAQmxUtil.dll
05/24/2004  01:43 PM            65,536 NationalInstruments.DotNET.Common.dll
07/23/2003  05:36 AM            32,768 NationalInstruments.DotNET.ComponentWizard.dll
02/23/2007  08:09 PM            53,248 NationalInstruments.DotNET.DAQmxAssistantWizards.dll
07/23/2003  05:31 AM            20,480 NationalInstruments.DotNET.IIOAssistantWizards.dll
07/23/2003  05:37 AM            45,056 NationalInstruments.DotNET.ProjectWizards.dll
07/23/2003  06:17 AM            24,576 NationalInstruments.Interfaces.dll
07/23/2003  06:39 AM           278,528 NationalInstruments.MeasurementStudio.dll
07/23/2003  05:38 AM            36,864 NationalInstruments.MxbCodeGenerator.dll
02/23/2007  08:19 PM            32,768 NationalInstruments.ParameterAssistant.DAQmxProvider.dll
07/23/2003  05:35 AM            28,672 NationalInstruments.ParameterAssistant.DataSocketProvider.dll
07/23/2003  05:23 AM            53,248 NationalInstruments.ParameterAssistant.dll
07/23/2003  05:30 AM            24,576 NationalInstruments.ParameterAssistant.GpibProvider.dll
02/16/2007  02:50 PM            32,768 NationalInstruments.ParameterAssistant.VisaProvider.dll
05/24/2004  01:43 PM           499,712 NationalInstruments.VSDesigner.dll
07/23/2003  05:14 AM             1,078 nilogo.ico
07/23/2003  06:41 AM           294,912 ToolHost.dll
(3,706 Views)
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders
Class Name:        <NO CLASS>
Last Write Time:   6/7/2007 - 11:14 AM
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxDeviceProvider
Last Write Time:   6/5/2007 - 4:45 PM
Value 0
  Type:            REG_SZ
  Data:            NationalInstruments.ParameterAssistant.DAQmxProvider.dll
Value 1
  Type:            REG_SZ
  Data:            DAQmx
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxDeviceProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxDeviceProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxGlobalChannelProvider
Value 0
  Type:            REG_SZ
  Data:            DAQmx
Value 1
  Type:            REG_SZ
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxGlobalChannelProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxGlobalChannelProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxPhysicalChannelProvider
Value 0
  Type:            REG_SZ
  Data:            DAQmx
Value 1
  Type:            REG_SZ
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxPhysicalChannelProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxPhysicalChannelProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxScaleProvider
Value 0
  Type:            REG_SZ
Value 1
  Type:            REG_SZ
  Data:            DAQmx
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxScaleProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxScaleProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
(3,704 Views)
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxSwitchProvider
Last Write Time:   6/7/2007 - 11:13 AM
Value 0
  Type:            REG_SZ
 Data:            DAQmx
Value 1
  Type:            REG_SZ
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxSwitchProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTaskProvider
Value 0
  Type:            REG_SZ
  Data:            DAQmx
Value 1
  Type:            REG_SZ
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTaskProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTaskProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTerminalProvider
Value 0
  Type:            REG_SZ
Value 1
  Type:            REG_SZ
  Data:            DAQmx
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTerminalProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTerminalProvider\SupportedClassLibraries
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTriggerProvider
Value 0
  Type:            REG_SZ
  Data:            DAQmx
Value 1
  Type:            REG_SZ
(3,703 Views)
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DAQmxProviders.DAQmxTriggerProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DataSocketProviders.DataSocketAccessModesProvider
Last Write Time:   6/7/2007 - 9:37 AM
Value 0
  Type:            REG_SZ
  Data:            DataSocket
Value 1
  Type:            REG_SZ
  Data:            NationalInstruments.ParameterAssistant.DataSocketProvider.dll
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DataSocketProviders.DataSocketAccessModesProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DataSocketProviders.DataSocketSourceURLProvider
Value 0
  Type:            REG_SZ
Value 1
  Type:            REG_SZ
  Data:            DataSocket
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.DataSocketProviders.DataSocketSourceURLProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.GpibProviders.GpibProvider
Value 0
  Type:            REG_SZ
  Data:            NationalInstruments.ParameterAssistant.GpibProvider.dll
Value 1
  Type:            REG_SZ
  Data:            Gpib
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.GpibProviders.GpibProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.VisaProviders.VisaResourcesProvider
Last Write Time:   6/5/2007 - 4:46 PM
Value 0
  Type:            REG_SZ
  Data:            NationalInstruments.ParameterAssistant.VisaProvider.dll
Value 1
  Type:            REG_SZ
  Data:            Visa
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Measurement Studio\7.0\ParameterAssistantProviders\NationalInstruments.ParameterAssistant.VisaProviders.VisaResourcesProvider\SupportedAssemblies
Value 0
  Type:            REG_SZ
  Data:
(3,702 Views)
mrSnow,
The problem is most likely continuing past a reinstall due to drivers having Measurement Studio support installed with them. If you have the drivers still installed with Measurement Studio support, we will need to also remove and reinstall or repair those. This includes any components having to do with Measurement Studio, including the DAQ Assistant and any other assistants installed. This will allow you to have everything gone from Measurement Studio and install fresh without any problems in the registry.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(3,685 Views)
