Working with cursors on WPF graph
Hello friends,
I have been working on how to use cursors with a WPF graph in an MVVM application but I am having trouble accomplishing a few things. I have created a cursor on my graph with the following statement...
<ni:Cursor SnapToData="False" InteractionMode="Mouse" AllowablePlots="Single" Plot="{Binding ElementName = channelPlot}" HorizontalCrosshairLength="0" TargetSize="0,0"/>
I set the HorizontalCrosshairLength to 0 because I am only interested in the vertical crosshair. I set the TargetSize to 0,0 because I do not need anything to display at the intersection of the crosshairs.
With that being said I have the following questions...
  1. At the intersection of the vertical & horizontal crosshairs, the X and Y value of the intersection are displayed, how can I hide these X and Y values?
  2. How can I set the default position of my vertical crosshair?
  3. How can I change the color of my cursor?
Thanks!
(4,597 Views)
Accepted by topic author b!tmaster
1) You can use the ValueVisibility property to hide the display of the value.
2) By default, a Cursor takes a position in the center of the plot area at the time it is loaded into a graph. To change this position, you will need to call one of the Set*Position methods, such as SetRelativePosition or SetDataPosition.
3) Since you are hiding the target, you can use the CrosshairBrush property to change the color of your cursor.
~ Paul H
(4,555 Views)
phasen,
  1. I set the ValueVisibility property to collapsed and this removed the value display.
  2. Unfortunately I think I am going to have to break my MVVM pattern to use the Set*Position methods in my code behind but regardless, thanks for pointing out which methods I need to move cursor position.
  3. I am now able to change the color of my cursor using the mentioned property.
Thanks for your help!
(4,552 Views)
For the Set*Position methods, you could also optionally create an attached property to do a one-time set using XAML, if that makes more sense for your scenario.
~ Paul H
(4,549 Views)
It sounds like that may make more sense for my scenario, I am unaware of how to implement an attached property though so I will do some research.
(4,547 Views)
From a quick search, this article might be a helpful reference: Introduction to Attached Behaviors in WPF.
~ Paul H
(4,538 Views)
Thanks for the reference, I realized that I am going to have to be able to set the position of the cursors repeatedly (not just one time) so I am just going to use the code behind approach.
(4,533 Views)
