YAxis Index of Waveformgraph.YAxisRangeChanged Event
Hi Everyone,
is there a possiblity to get the index of the YAxis, if three plots in the Waveformgraph Graph1 with YAxis are used:
private void Graph1_YAxisRangeChanged(object sender, NationalInstruments.UI.YAxisEventArgs e)
    NationalInstruments.UI.WindowsForms.WaveformGraph graph = (NationalInstruments.UI.WindowsForms.WaveformGraph) sender;
    Debug.Write(graph.Name);
Reason for this is, that I would like to restrict the minimum range used in the different plots.
Thanks in advance,
Michael
(2,261 Views)
Were you able to find solution to this question?
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,189 Views)
