adding plots
I was under the impression that if I specified a xy value on a scatter graph then that point would be displayed as a single point. this does not appear to be the case. I have tried to create a new plot but cannot find the correct method for doing this. I am new to ni ms and would appreciate some help. I am looking to produce a chart with x1y1 - x2y2 then a second plot, further along the same x axis of x3y3-x4y4.I thought I could do it on a single plot but this does not seem to be the case. I am using vb in vs2010. any help greatly appreciated....
(5,250 Views)
Accepted by topic author calydel
Is this what you're looking for?
   Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Try
            With ScatterPlot1
                .LineStyle = NationalInstruments.UI.LineStyle.None
                .PointStyle = NationalInstruments.UI.PointStyle.SolidDiamond
                .PointColor = Color.Lime
            End With
            With ScatterPlot2
                .PointColor = Color.Cyan
            End With
            ScatterGraph1.XAxes.Item(0).Mode = AxisMode.Fixed
            ScatterGraph1.XAxes.Item(0).Range = New Range(0, 10)
            ScatterGraph1.YAxes.Item(0).Mode = AxisMode.Fixed
            ScatterGraph1.YAxes.Item(0).Range = New Range(0, 10)
            Dim xdata(1) As Double
            Dim ydata(1) As Double
            xdata(0) = 2
            xdata(1) = 6
            ydata(0) = 2
            ydata(1) = 6
            ScatterPlot1.PlotXY(xdata, ydata)
            xdata(0) = 3
            xdata(1) = 6
            ydata(0) = 4
            ydata(1) = 9
            ScatterPlot2.PlotXY(xdata, ydata)
        Catch ex As Exception
        End Try
    End Sub
Hope this helps
Curt
(5,245 Views)
thanks for the response. Works fine.
(5,240 Views)
