aiterminalconfiguration question
When specifying the AITerminalConfiguration I see it in the examples as (AITerminalConfiguration)(-1) or CType(-1,AiTerminalConfiguration)
What does the -1 mean when the enums are
Nrse = 10078,
Rse = 10083,
Differential = 10106,
Pseudodifferential = 12529?
Andy
(4,598 Views)
-1 is the default value that is set at run time, NI-DAQmx chooses the default terminal configuration for the channel. The default is that which you may have set in MAX (measurement and automation explorer). You may be able to use a property node to programatically obtain what the default might be?
I hope this helps!
Kind Regards
Kurt
(4,577 Views)
Kurt
thanks for that. Sorry for the delay in replying... I was moving house.
Andy
(4,557 Views)
