analog multi channel writer example for Visual Basic .NET?
Hi all - I found the C# example and I was wondering if anyone has (or knows where to find) an example for using the AnalogMultiChannelWriter in Visual Basic .NET.
Thanks!
(4,697 Views)
Hi, do you use a specific DAQ cards (Like 6008?)
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,643 Views)
The location of the .NET Examples for DAQ are based on the version of NI-DAQmx you have. Assuming you have version 8.5 or later, they are located in:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNetx.x
where x.x refers to your version of the .NET Framework.
This information is found at:
KnowledgeBase 47CCSQ5B: NI-DAQmx, NI-VISA and NI-488.2 .NET Example Locations
In this directory, you can get to the AnalogWriter examples and pick one from:
\Analog Out\Generate Voltage\
Jervin Justin
NI TestStand Product Manager
(4,596 Views)
