binding data in single xpf graph for multiple xy chart plots
I am evaluating MS2013 in VS2012.  I have a long history with MS and Visual C++.  My goal is charting frequency vs voltage data from two dac channels.  I collect data at a particular frequency for two channels, process the data, and then chart the two resulting xy points.  As noted in earlier posts i found examples of binding a single xy data set via an array of points bound with .DataSource but not a means for binding to multiple plots.  I tried without success to find a ChartCollection that would handle a double as index and two y double values.
Stated a different way I would like to bind two XY chart plots in a single wpf NI:Graph to a data source I can fill over time and have the graph chart the entire time period.
My apologies if i have missed a piece of documentation that addesses this requirement.
(5,472 Views)
I got close to what I had in mind by using an observableCollection of Point arrays as a data source.
(5,439 Views)
Accepted by topic author joemg
Unfortunately, we do not have any pre-defined data types that will chart multiple Y values against a single X value. Using an ObservableCollection<Point[]> is a valid approach.
If you are charting (X values are always increasing), then you could use an array of ChartCollection<double,double> instead, and mimic a multi-value chart using an extension method:
    public static class ChartExtensions {
        public static void Append( this ChartCollection<double, double>[] charts, double x, params double[] ys ) {
            for( int i = 0; i < ys.Length; ++i ) {
                double y = ys[i];
                var chart = charts[i];
                chart.Append( x, y );
~ Paul H
(5,432 Views)
Looks good to me.  Thx.
Solved.
(5,426 Views)
