08-21-2006 02:15 PM
08-22-2006
08:47 AM
- last edited on
07-25-2026
04:35 PM
by
Content Cleaner
08-22-2006 01:07 PM
08-24-2006 12:56 PM
NationalInstruments.Common installed on your machine is newer than the version that the project originally referenced. The NationalInstruments.Common assembly is designed to be backward compatible with older versions. The NationalInstruments.Common
assembly uses publisher policy to redirect references from older
versions to newer versions. Therefore, it is safe to disregard this
warning and use the latest version of the NationalInstruments.Common assembly. 08-24-2006 04:13 PM
08-25-2006 10:34 AM
08-25-2006 11:39 AM
Thank you for that further explanation.
I am going to print this thread and keep it as a reference.
