call Hilbert Transform in my C++ app
Hey!
I wanna use Hilbert Transform to get the envolope of the signal acquired from the PCI-6115 DAQ board. I wrote my application in C++ (under .NET 2003). Is there any library that provides Hilbert Transform function?
In my LabView 7 Express, it seems there is a "lvanlys.dll" which contains a function "long FastHilbertTransformH(void *xH, long *tbl)". But how can I call it in my own C++ application?
Thanks and Regards,
Tim
(5,030 Views)
Hello
Measurement Studio Professional and higher provides CNiMath::FastHilbertTransform() for use with Visual C++ (MFC based apps) in Visual Studio .NET 2003.
I hope this helps.
Bilal Durrani
NI
(5,020 Views)
I am gonna try that. Thanks a lot!!
(5,013 Views)
hey Bilal,
I am wondering, does "CNiMath::FastHilbertTransform()" use FFT/IFFT to implement the hilbert transform? or in other way?
I care a lot about the speed; if it uses FFT/IFFT, it would not meet our requirement.
-- Tim
(4,992 Views)
The algorithm used by the FastHilbertTransform is documented in the help for that method. It'll provide more insight on how this operation is being performed. If you go the help index, select Measurement Studio C++ libraries in the filter and type in "FastHilbertTransform", it should take you to the topic.
Bilal Durrani
NI
(4,982 Views)
