can't write data using measurement studio datasocket
I'm trying to connect a datasocket to a file and write Data.
        private const string TargetDataFile    = "file:c:/DATA_1000_R_Data.txt";
This works -->            dataSocketRefData.Connect(TargetDataFile,AccessMode.WriteAutoUpdate);
and I can see the file created in the root directory.
But when I try and do this is when I get "Error:Can't write Data"
            dataSocketRefData.Data.Attributes.Add("Timestamp", DateTime.Now);
I'm using Measurement Studio 7.1 running on  XP Pro
Thanks Dan
(3,975 Views)
Hi Dan:
Do you have a file that I can use at this end to replicate the issue?
The following link might have some information useful to you:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E43956A4E034080020E74861&p_node=174961&p_source=External
Nandini
(3,966 Views)
Hi Nandini:
I looked at the example but unfortunately you can't select a file to write to "file:......." only "dstp://". Here's a sample solution you can test.
sing System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
using NationalInstruments.Net;
namespace datasocketest
    /// <summary>
    /// Summary description for Form1.
    /// </summary>
    public class Form1 : System.Windows.Forms.Form
        private NationalInstruments.Net.DataSocket dataSocketIOREF;
        private System.ComponentModel.IContainer components;
        private System.Windows.Forms.Button Startbutton;
        private System.Windows.Forms.TextBox StatusBox;
        private const string TargetDataFile    = "file:f:/temp/Ref_Data";
        public Form1()
            // Required for Windows Form Designer support
            InitializeComponent();
            // TODO: Add any constructor code after InitializeComponent call
        /// <summary>
        /// Clean up any resources being used.
        /// </summary>
        protected override void Dispose( bool disposing )
            if( disposing )
                if (components != null)
                    components.Dispose();
            base.Dispose( disposing );
        #region Windows Form Designer generated code
        /// <summary>
        /// Required method for Designer support - do not modify
        /// the contents of this method with the code editor.
        /// </summary>
        /// <summary>
        /// The main entry point for the application.
        /// </summary>
        [STAThread]
        static void Main()
            Application.Run(new Form1());
        private void dataSocketIOREF_ConnectionStatusUpdated(object sender, NationalInstruments.Net.ConnectionStatusUpdatedEventArgs e)
            StatusBox.Text = e.Message;
        private void Startbutton_Click(object sender, System.EventArgs e)
            dataSocketIOREF.Connect(TargetDataFile,AccessMode.WriteAutoUpdate);
            dataSocketIOREF.Data.Attributes.Add("Timestamp", DateTime.Now);
Best Regards;
Dan
(3,959 Views)
Nndini:
Here's the rest of it
    private void InitializeComponent()
            this.components = new System.ComponentModel.Container();
            this.dataSocketIOREF = new NationalInstruments.Net.DataSocket(this.components);
            this.Startbutton = new System.Windows.Forms.Button();
            this.StatusBox = new System.Windows.Forms.TextBox();
            ((System.ComponentModel.ISupportInitialize)(this.dataSocketIOREF)).BeginInit();
            this.SuspendLayout();
            // dataSocketIOREF
            this.dataSocketIOREF.SynchronizingObject = this;
            this.dataSocketIOREF.ConnectionStatusUpdated += new NationalInstruments.Net.ConnectionStatusUpdatedEventHandler(this.dataSocketIOREF_ConnectionStatusUpdated);
            // Startbutton
            this.Startbutton.Location = new System.Drawing.Point(32, 32);
            this.Startbutton.Name = "Startbutton";
            this.Startbutton.TabIndex = 0;
            this.Startbutton.Text = "Start";
            this.Startbutton.Click += new System.EventHandler(this.Startbutton_Click);
            // StatusBox
            this.StatusBox.Location = new System.Drawing.Point(8, 192);
            this.StatusBox.Name = "StatusBox";
            this.StatusBox.Size = new System.Drawing.Size(248, 20);
            this.StatusBox.TabIndex = 1;
            this.StatusBox.Text = "Status";
            // Form1
            this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
            this.ClientSize = new System.Drawing.Size(292, 266);
            this.Controls.Add(this.StatusBox);
            this.Controls.Add(this.Startbutton);
            this.Name = "Form1";
            this.Text = "Form1";
            ((System.ComponentModel.ISupportInitialize)(this.dataSocketIOREF)).EndInit();
            this.ResumeLayout(false);
        #endregion
(3,957 Views)
