casting
I have a DataSocket object, a AutoRefresh control and a Gauge.
In the AutoRefresh event I have:
Gauge1.Value = (Double) dataSocket.Data.Value
However, this seems to cause a type casting error at run time.
Seb
(4,852 Views)
You could try,
Gauge1.Value = DataConverter.Convert<Double>(dataSocket.Data.Value);  (if you are using VS2005)
or
Gauge1.Value = (Double)DataConverter.Convert(dataSocket.Data.Value, typeof(Double)); (if you are using VS2003)
But, you need to be sure that what you are sending CAN be converted to Double. If you are sending a Double[], then this may not work. However, if you are sending an Int32 or some other primitive type and you want that to be converted to Double, DataConverter will take care of that for you.
In any case, you can just see
once what dataSocket.Data.Value.GetType() returns, and then change you code to typecast to that type and then get the double value from the typecasted dataSocket.Data.Value.
-Mahesh
(4,826 Views)
Hello again, How can I find out what data type the OPC server is sending ? Seb
(4,818 Views)
Will the dataSocket.Data.Value.GetType().ToString() work for you ?
-Mahesh
(4,782 Views)
GetType().ToString() returns
System.Int32
but casting to System.Int32 does not work
(4,778 Views)
Are you sure, dataSocket.Data.Value.GetType().ToString() returned System.Int32 and not System.Int32[] ?
As I said earlier, if you are not dealing with arrays, then simply let the DataConverter take care of that for you.
Is the above line also not working for you ?
-Mahesh
(4,762 Views)
