configure rtsi cable with daqmx
Hello!
I read many posts about synchronize multiple devices via rtsi cable.
The synchronization is working well.
But can I configure the rtsi cable with the daqmx api or is it necessary to do it with MAX?
I use 9.3.5
Christian
(5,913 Views)
Hi Christian,
This is possible with DAQmx property nodes. Please have a look at this KB:
Programmatically Routing PXI Trigger Lines Across a Multi Segment PXI Chassis
http://digital.ni.com/public.nsf/allkb/A4DA71CA2F68306686256ED8005515ED
Programmatically Route PXI Trigger Lines Across a Multi Segment PXI Chassis in LabVIEW
https://decibel.ni.com/content/docs/DOC-25650
Cheers,
Philip
(5,882 Views)
Thanks for your reply. I'm using .net 4.0 and C#. But I found no functions to this with the provided API for C#. Do you know the necessary functions in c#? Thanks, Chris
(5,842 Views)
