connecting to yokogawa mx100 using measurement studio.NET
I am developing an application that required to acquire data from yokogawa MX100 and than log the data to database. I build my application using Visual Studio.NET with Measurement Studio Component installed. The problem is I couldn't found device driver of Yokogawa MX100 for Measurement Studio. Any idea to solve this problem?
(3,750 Views)
codebreak,
You could check the Instrument Driver Network on ni.com to see if there is a driver available, or the instrument manufacturer's website (remember drivers for .NET or C++ would work).  If neither of those have drivers then it is likely you will have to communicate with the device in a protocol supported by the instrument (Serial/RS232, GPIB, Ethernet, etc) and use lower-level programming to send information back and forth.
John B.
(3,702 Views)
