constant analog output
This has to be simple task, but I seem to be missing something.
I would like to generate a constant voltage on one of the AO channels (the output goes to a fan controller that controls fan speed). How do I generate a constant voltage on the AO channel? I've looked at the examples and they all generate waveforms (sine, square, etc.). I'll update/modify this voltage perodically based on temperaturements I'm taking (over serial communication, not via the DAQ). I suspect I'll update the voltage every minute or so.
Sorry about asking such a simple question, but I've looked at the examples and don't quite understand.
thanks in advance,
phil
(3,586 Views)
Hi Phil,
Check out the GenVoltageUpdate example under ProgramFiles...DAqmx\Examples\Analog Out\Generate Voltage\GenVoltageUpdate\
This generates a single voltage value every time you click on the Start/Generate button. You could probably use this example as a starting point.
Hope this helps...
Nandan Dharwadker
Staff Software Engineer
Measurement Studio Hardware Team
(3,580 Views)
Thank you very much. I was looking at the wrong examples.
phil
(3,578 Views)
