create tank in form c#
Hi all
I create a Tank control  in my Window Form but de Fill Area donsn't  reflect the Value of de Tank, Can Any body Helpme please ?
private void Form1_Load(object sender, EventArgs e)
NationalInstruments.UI.WindowsForms.Tank bat1 = new NationalInstruments.UI.WindowsForms.Tank();
((System.ComponentModel.ISupportInitialize)(bat1)).BeginInit();
bat1.Name = "bat1";
bat1.Location = new System.Drawing.Point(100, 200);
bat1.Size = new System.Drawing.Size(100, 200);
bat1.ScaleVisible = true;
bat1.Visible = true;
bat1.Range = new Range(0, 20);
bat1.FillColor = Color.Red;
bat1.Value = 30;
bat1.TankStyle = TankStyle.Raised;
bat1.FillMode = NumericFillMode.ToMinimum;
bat1.FillBaseValue = 0;
bat1.FillStyle = FillStyle.Solid;
this.Controls.Add(bat1);
this.Refresh();
(7,273 Views)
Your range is 0 to 20, but your value is 30.
(7,271 Views)
It donsn't matter the value, it does not change, I've tried value=5, value=8, etc.. but it never chenge
(7,268 Views)
I am not sure why you are using
 but when I comment it out, I see a tank that is filled with red.
I am using Measurement Studio 2010 with C# 2010 Express.
(7,244 Views)
I took this line from a example, I commented out this line worked,  thanks very much.
(7,234 Views)
There are several examples installed by default.
You should view them to see how to use Measurement Studio properly.
(7,230 Views)
