cwShapeMinMaxRegion .Net Equivalent
Is there an equivalence of the shape type in vb6 named cwShapeMinMaxRegion ?
(3,676 Views)
Are you using WPF or Windows Forms in your .NET application?
What kind of appearance/behavior are you looking to achieve? It would be very helpful if you could provide a screenshot of the VB6 effect you are looking for.
~ Paul H
(3,664 Views)
Actually, I think the vb6 property that makes the trick is the cwRegionInverted. This is what I am trying to achieve
I am using XYRangeAnnotation setting up values for YRange (-5,5) and XRange(Negativeinfinity, PositiveInfinity) but I cant invert the annotation like vb6 property did.
I am using Winforms
I dont know if the only way to achieve that it is using two annotations one from the top and one for the bottom
(3,658 Views)
Accepted by topic author mobdev
I do not believe the XYRangeAnnotation class offers an equivalent of cwRegionInverted. To achieve the same effect, you would need to use two range annotations: one from -Infinity to -5, and one from 5 to +Infinity.
~ Paul H
(3,643 Views)
Yes, that the best solution we can find
(3,640 Views)
