daq custom installation
Having developed an application using VS .Net and Measurement Studo .NET, I need to include the daqmx drivers.  I would like to do this using a custom installation.  "Creating a silent customized installer for Ni_DAQmx" describes the process and includes a daqmx80_specfile.txt.  Unfortunately there doesn't appear to be any documentation linking the lines in this file to the options you see when you do an installation.  I thought I could do the installation manually and then find a file that listed the installed options, which could then be copied to the spec file.  Unfortunately, I haven't been able to find such a file.  My simple question then is "How do I work out what options in the specfile I need?"  Is there some documentation or other method to discover what options to set to local
By the way, I note that if you do a silent install, it suppresses error messages, so you can think that all went well, when, in fact, some components weren't installed.  Not good.
Message 1 of 1
(3,440 Views)
