daqmx multi device synchronization for analog output - pci m series devices
Hi all,
    I'm trying to synchronize 2 PCI 6259 M series boards for a synchronized analog output operation using C#. NET. I did check the example provided for AI and borrowed heavily from the same. I did verify the hardware connectivity using the RTSI cable. Unfortunately, I'm unable to get the master task to start, while the slave starts without the master trigger. A quick gist is as follows.
1. Sample output waveform read from file, sample rate and samples per ch defined
2. Master and Slave channels defined, timing and synchronization set up w.r.t master (code snippet attached)
3. The Slave is set to start once the master task is fired.
When I run the task thru debug mode, I do get the desired output, all output signals are in sync. But when run "normally", the master does not get started while the slave outputs an arbitrary portion of the waveform. No exceptions thrown, but I'm nowhere near a desired result. Any help on this is greatly appreciated.
Code:
              //Declare all the tasks
                myTask = new Task("inputTask"); // AI task
                myMaster = new Task("masterTask");
                mySlave = new Task("slaveTask");
                myMasterWriter = new AnalogMultiChannelWriter(myMaster.Stream);
                mySlaveWriter = new AnalogMultiChannelWriter(mySlave.Stream);
# Waveform Read from file, outputting 2 double arrays.......
                //Configure the master and slave task
                myMaster.AOChannels.CreateVoltageChannel("Dev1/ao0", "", -10, 10, AOVoltageUnits.Volts);
                myMaster.AOChannels.CreateVoltageChannel("Dev1/ao1", "", -10, 10, AOVoltageUnits.Volts);
                myMaster.Timing.SampleClockRate = outputSampleRate;
                myMaster.Control(TaskAction.Verify);
                double correctUpdateRate = myMaster.Timing.SampleClockRate;
                myMaster.Timing.ConfigureSampleClock("", correctUpdateRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, outWF.GetLength(1));
                myMaster.Stream.Timeout = -1;
                //Second the slave
                mySlave.AOChannels.CreateVoltageChannel("Dev2/ao0", "", -10, 10, AOVoltageUnits.Volts);
                mySlave.AOChannels.CreateVoltageChannel("Dev2/ao1", "", -10, 10, AOVoltageUnits.Volts);
                mySlave.Timing.SampleClockRate = outputSampleRate;
                mySlave.Control(TaskAction.Verify);
                double correctSlaveUpdateRate = mySlave.Timing.SampleClockRate;
                mySlave.Timing.ConfigureSampleClock("", correctSlaveUpdateRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, outSlaveWF.GetLength(1));
                mySlave.Stream.Timeout = -1;
                //Synchronize master and slave by using on-board clock
                myMaster.Timing.ReferenceClockSource  = "OnboardClock";
                mySlave.Timing.ReferenceClockSource = myMaster.Timing.ReferenceClockSource;
                mySlave.Timing.ReferenceClockRate = myMaster.Timing.ReferenceClockRate;
                mySlave.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("/Dev1/ao/StartTrigger", DigitalEdgeStartTriggerEdge.Rising);
                myMasterWriter.WriteMultiSample(false, outWF);
                mySlaveWriter.WriteMultiSample(false, outSlaveWF);
  //Start the tasks
                mySlave.Start();
                myMaster.Start();
               myMaster.Stop();
                mySlave.Stop();
                myMaster.Dispose();
                mySlave.Dispose();
(4,289 Views)
Hi Dawdler,
Have you tried this code with different clock rates? And then, have you tried this setting a small delay between the start task command? Would you post your code in a file?
steve.bm
AE | NI
(4,274 Views)
