delay in output
hi all,
i am developing an application using Measurement Studio for .NET, and image acqusition is done with a IEEE1394 camera.well,my problem is a certain delay in the execution of the program..for instance,if i want to do color matching and display the color in a message box, it doesnt appear at once.even when i removed the message box and just returned the color to a calling function,its still the same..when i debug it,though(using F11),it runs fine..there is a delay in saving the image in memory,and also in storing any other info from any image processing function(in my case,the LearnColor function).i had to insert a delay between LearnColor and MatchColor to make sure the color information was saved properly.without the delay,the program just throws an unhandled exception at MatchColor.
my question is, whether this is caused by the camera,or inherent in Vision,or could the speed of my computer be a factor too?if its any of the 1st two,is there a way around it?
thank u..
(5,044 Views)
Hello rebecs,
Would it be possible for you to post your project to the forum, so we can take a look at it?  I would like to run the code you are using to see if I can duplicate the problem.  Thank you.
Jasper S
(5,035 Views)
hi jasper,
here is my code:
Public Class VisionTool
Dim ViewRect As New NationalInstruments.CWIMAQControls.CWIMAQRegions
Dim ColInfo As New NationalInstruments.CWIMAQControls.CWIMAQColorInformation
Dim Scores As Object
Dim sid As System.UInt32
Dim errorCode As Integer
Public IMAQVision As NationalInstruments.CWIMAQControls.AxCWIMAQVision
Dim myImage As NationalInstruments.CWIMAQControls.CWIMAQImage
Dim BufferNumber As Integer
Private WithEvents t1 As System.Timers.Timer
' A creatable COM class must have a Public Sub New()
' with no parameters, otherwise, the class will not be
' registered in the COM registry and cannot be created
' via CreateObject.
Public Sub New()
MyBase.New()
IMAQVision =
New NationalInstruments.CWIMAQControls.AxCWIMAQVision
IMAQVision.CreateControl()
'image initialization
myImage =
New NationalInstruments.CWIMAQControls.CWIMAQImage
myImage.Type = NationalInstruments.CWIMAQControls.CWIMAQImageTypes.cwimaqImageTypeRGB32
'timer initialization
t1 =
New System.Timers.Timer(250)
errorCode = CWIMAQ1394.CameraOpen2("cam0", CWIMAQ1394.CameraMode.IMG1394_CAMERA_MODE_CONTROLLER, sid)
If (errorCode <> CWIMAQ1394.ErrorCodes.IMG1394_ERR_GOOD) Then
Console.WriteLine(" camera error!!")
GoTo ErrorHandler
End If
t1.Enabled =
True
errorCode = CWIMAQ1394.SetupGrabCW(sid)
Console.WriteLine(" grab error!!")
GoTo ErrorHandler
End If
ErrorHandler:
End If
End Sub
Public Function GetLedColor() As Integer
Dim roi As New CWIMAQRegions
Dim roiRect As New CWIMAQRectangle
System.Threading.Thread.Sleep(250)
roiRect.Initialize(111, 54, 7, 15)
ViewRect.AddRectangle(roiRect)
IMAQVision.LearnColor(myImage, ColInfo, ViewRect)
IMAQVision.MatchColor(myImage, ColInfo, Scores, ViewRect)
IMAQVision.Dispose()
Return Scores(0)
End Function
Public Sub TimerFired(ByVal sender As Object, ByVal e As System.Timers.ElapsedEventArgs) Handles t1.Elapsed
errorCode = CWIMAQ1394.Grab2CW(sid, 1, BufferNumber, myImage)
Console.WriteLine("timer error")
t1.Enabled =
False
End If
End Sub
End
Class
i am calling this library from a tcl script,using DOS(i mean i run the tcl script from DOS command prompt)..and it is supposed to return the score of the color matching function to the calling program.
for now,it is returning the score..but it is taking some time..as for the first time it is called,it takes forever..Smiley Mad when i posted this question in one of the forums earlier, someone suggested that maybe there is some delay needed for marshaling between .NET and COM...that is from the .NET/COM perspective..wat about the NI perspective?does any of the NI function have an inherent delay?or is this purely dependent on the machine im using?
thanks so much...Smiley Happy
(5,022 Views)
Hello rebecs,
In this case it looks like these delays are expected.  They are inherent to the Vision functions you are calling, and are in no way related to your camera.  The speed of your computer will also be a factor in how long they take to populate their memory spaces.  What is interesting in this case is that they do not block, as you are well aware of.  This means the function returns before the memory operation is complete.  Let me know if you have any other questions regarding this issue.
Jasper S
(4,994 Views)
hello jasper,
thank u so much for ur reply..well,since the delay is expected,i guess i have to make do with it...at least my application works.Smiley Very Happy
(4,987 Views)
To speed Up your process, you can change your architecture:
- create a Windows Service which connects permanently the camera and IMAQ. Some kind of "out of process" COM executable
- create a small EXE that will exchange small information with the COM server.
That architecture will be VERY fast : you won't have to load all the DLLs each time because they will be already loaded and running !
(4,101 Views)
