display waveformGraph from txt file data
How to use the waveformGraph to display the moving chart based on the collected data (data from txt file)? How to incorporate the received / custom data (instead of random generated data)?
Programming Languages: C#, Measurement Studio
(3,291 Views)
There is not only one way to display a data collection from a file. It also depends on your file structure.
But you can do something like that :
1) load the data at the application startup, for instance
_data = new ArrayList( 1000 );
using( StreamReader streamReader = new StreamReader( _fileName ) )
String line = streamReader.ReadLine();
while( line != null )
_data.Add( Convert.ToDouble( line ) );
_data.TrimToSize();
2) use a timer / thread to chart the data, for instance
_graph.PlotYAppend( _data[ _currentDataIndex ], _dataSize );
++_currentDataIndex;
if( _currentDataIndex >= _data.Count )
_currentDataIndex = 0;
(3,283 Views)
